Southwest Region Dual in the desert/ HOBBS NM/ May 14
AZ,CA,NM,NV,UT
  • 2
723
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
731
834
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
speedyjuarez
Premium Member
Premium Member
speedyjuarez
Live in Hobbs, NM. From Ft Worth, TX
BEEKAY
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
