Pilot Alternator suggestions
argenis69
SQ Bass Lover
844
NY, USA
Hello,
I recently bought a 2016 Honda Pilot and I want to install the system I had in my Maxima in the Pilot.
So, I want to add a bigger or second alternator on the Pilot to avoid damage or electrical stress.
Keeping in mind that I don't want to spend a fortune on this:
1- What do you suggest for me to do?
2- Which alternator should l buy? Any adapter needed?
Thank you.
Hello,I recently bought a 2016 Honda Pilot and I want to install the system I had in my Maxima in the Pilot.
Thank you.
what trim level. the part# I listed is for lx-touring, if you have an elite then the part number I listed is incorrect
if the alt has a CANBUS interface for regulating the output, you won't get an aftermarket alt. you can have a stock alt modded to maintain the CANBUS communication.
even with the upgrade, the PCM will still control the alternator to save fuel. it's something Honda has done for 20 years.
did you verify if your stock alt has CANBUS control?
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
Get the vehicle you want first then come back and see about some recommendations. Id also recommend placing some power on components,as HU power...
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
504
I don't have one...but I check my voltage with a dmm once a week or so
654
argenis69
SQ Bass Lover
argenis69
NY, USA
keep_hope_alive
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
