Struggling to remove an Alpine CDA-9807 from the DIN cage
  • 2
Tempe
FI Car Audio FTW!!!
I did my first install back in 1998. It's been about five years since I've done any install work, but I figured it would be a simple swap and move on with my night. After about 45 minutes I gave up trying to remove the unit. Normally you remove the faceplate, remove the trim ring, and slide those thin metal tools into each side of the stereo to release the unit from the DIN cage. That's exactly how it's worked on my past head units and how it works with the Pioneer unit that's going into this car. This is what the Alpine owner's manual says to do:
Removal
1 Remove the DETACHABLE FRONT PANEL.
2 Use a small screwdriver (or similar tool) to push the
locking pins to the “up” position (see above drawing). As
each pin is unlocked, gently pull out on the unit to make
sure it does not re-lock before unlocking the second pin.
3 Pull the unit out, keeping it unlocked as you do so.
Because you're not sliding any tools into the din cage like on other head units, I've found no way to "pull the unit out." I'm sorry that I did not include a photo. Can anyone shed some light on this matter? Thanks!!!
Tempe
did you personally install this or did it come with the car?
a head unit can be installed with an ISO mount which bolts it to the chassis, meaning you need to remove the entire trim to get the HU out.
i typically use ISO mount when possible, or add screws into the side of the head unit making them difficult to remove and requiring removal of the entire dash trim.
simply remove the dash trim to gain access to the head unit.
the head unit is locked into the cage with these clips - halfway down the side of the unit
if the Pioneer doesn't have the exact same cage, you'll need to replace the cage.
I have used a piece of hard clear plastic from a retail package to remove a stereo before. I am only half joking when I say that you should just...
7
I’d suggest if you’re using 409. Get some wax paper or Saran Wrap. Soak the fabric in 409. Then lay the wax paper/ Saran Wrap over wherever the...
30
5K
This weekend I will be taking actual pictures for other sites. So grab it before its gone
6
308
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Tempe
FI Car Audio FTW!!!
Tempe
Gilbert, AZ
keep_hope_alive
ttt123
    Apr 16, 2024
ttt123
    Apr 16, 2024
Latest topics
