FS/FT Alpine MRV-F545
evilmonstertruk
Premium Member
Premium Member
1,144
Maryland
V12 High Power Amplifier
RMS Power Rating:
125 watts x 4 chan. @ 4 ohms
250 watts x 2 chan. (Ch 3-4 Only) @ 2 ohms
500 watts x 1 chan. (Ch 3-4 Only) @ 4 ohms
BridgedBlue LCD display: Shows off your system voltage, current, temperature, etc. for a killer install!
Detachable top cover to reveal the controls
Digital Information Center
Thermal Managment Processor
Amplifier Link: Connect to any compatible Alpine head unit for total control of your system.
Bass Engine:
Variable 30 - 400 Hz / 600 Hz - 8 kHz High- or Low-Pass Crossover
+16dB Bass Boost @ 45 Hz for Chan 3&4
MOSFET Power Supply: Gives clean clear sound
DC-DC PWM Power Supply
Discrete Pre-Amp Stage
STAR Circuitry
Solid Copper Bus Bars
Auto Over-Current Protection
MultiModeInput Mode Selector Switch
One Side Terminal Layout: Convenient locations for everything
Gold Plated RCA Input Connectors
Non-Fading Pre-Amp
Output Input Sensitivity: 200mV - 4V
(Individual control for channels 1&2, 3&4
Frequency Response: 10 Hz - 50 kHz
Dimensions: 16-1/2"*L*x 8-11/16"*W*x 2-5/16"*H
Very powerful and great sounding amp. Active capable. Replaced my Sundown SAX-125.4 with this and this clearly had more power in my opinion. No top cover and some screws are a little stripped. All can be found online.
150 obo shipped
Trade for Mono or two channel amps. Anything of equal value will be considered.
Thanks for looking
Sent from my Nexus 6 using Tapatalk
Set screws or plate screws are stripped?
Set. I think 3/4 channels. I got it like that. I was able to get them down when I installed so I never replaced them. Other than the cover that's the only issue. Looks **** good otherwise. And sounded great.
I may be interested in it. Pics would help.
942
I would swapp one of the front speaker wires on the amplifier to test the rear amplifier to test to see if they work/testing that way on each rear...
  • Locked
THESE ITEMS WILL BE REMOVED FROM THIS FOR SALE THREAD ON AUG.16,2022 @9PM CT. THANKS
12
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Umm the sub outputs. It's brand spanking new with an install booklet etc.
5
405
evilmonstertruk
Premium Member
Premium Member
evilmonstertruk
Maryland
soundquality4me
SlugButter
    Mar 28, 2024
SlugButter
    Mar 28, 2024
Latest topics
