Well considering the xfl came out years before the redline series even was thought of i highly doubt itThe AB is a copy of the DD. That's not to say that they are "the same". I haven't looked at the specs, but they may be quite different.
You use judgement to say which is better
If I were to guess, I'd say he was talking about the newest version, that looks like DD's redline series. The older XFL's don't look like the Redline 700'sWell considering the xfl came out years before the redline series even was thought of i highly doubt it
Helll right off the bat i see the redline has a 14mm xmax and 37fs and the xfl is 19mm and 31fsYes, the redline series is DD's "economy" option. Several people have said good things about the Redline series, including Fade. There's somebody on here who runs them
Same basket as SQ, AB, Massive, ect.
Yes, I said the same thing about specs. I doubt they're the same
I'm not disagreeing with thatHelll right off the bat i see the redline has a 14mm xmax and 37fs and the xfl is 19mm and 31fs
Yeah, probably same build house with different parts selectedboth made in china now...most likely side by side on the assembly line ...the only difference are the center caps ,boxes ,decals and stitching ....
The Redlines have always been made in China. The 800 redline uses US made soft parts.both made in china now...most likely side by side on the assembly line ...the only difference are the center caps ,boxes ,decals and stitching ....
So the xfl seems to be the better sub for Daily listning?Helll right off the bat i see the redline has a 14mm xmax and 37fs and the xfl is 19mm and 31fs
I didn't know the 800 line uses 4 inch coilsThe Redlines have always been made in China. The 800 redline uses US made soft parts.
