single Sundown SA 4ohm
  • 5
nate1017
About a week ago, i was riding home from work and one gave out on me soon as I pulled into to the driveway. Opened the trunk and smoke poured out of the port for about a minute. This has led me on the search to find another one to get me going right again. So if anyone has a DVC 4 ohm out the pm me please
May have, i had a puncture in the outer foam of cone not sure if that had anything to do with it
Get a o scope or dd1.... Check your power and ground for solid connection and corrosion
You just missed an SA 12 DVC 4 I had with approx 6 total hours of mild play time/still stiff as a board with original box and straight from Sundown.Guy got a hell of a deal shipped on it.
---------- Post added at 04:48 AM ---------- Previous post was at 04:47 AM ----------
What size are you looking for???10/12/15/18?
I second that, because I was the one who got it:p:
Good luck finding one on here op....I got tired and searching for a second one so just bought one new.
You should probably look into getting a smaller box built to help prevent this from happening again
Sounds like you need new coils. My Explorer with three 15's, appropriate birch box, fully sound-deadened interior, and a boat behind it does not...
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
323
583
nate1017
nate1017
DeFuniak Springs Fl
els1989
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
