around 240 amps. sorry it took so long i didn't get a notification for your reply.How big of a alt do you need.?
thanks. ill get a quote, but i hear mechman has better reliability???Singer is good stuff.
Currently waiting on my 370 amp hairpin.
Had a 320 amp hairpin in my car. Held high 13's with the M4a
Nope incorrect. Singer way better. I can give you a quote for singer or excessive amperagethanks. ill get a quote, but i hear mechman has better reliability???
I've heard the opposite, actually.thanks. ill get a quote, but i hear mechman has better reliability???
ok thanks. im looking for the most power without killing my wallet. is iraggi any good? 340amps for 499 sounds great.Nope incorrect. Singer way better. I can give you a quote for singer or excessive amperage
For a standard alt. yea. But be careful his work is hit or miss. Same with his cs. 320 hairpin from mike is $569.ok thanks. im looking for the most power without killing my wallet. is iraggi any good? 340amps for 499 sounds great.
That's a little to high for me I'm staying around the 400-500 range with good idle ampsFor a standard alt. yea. But be careful his work is hit or miss. Same with his cs. 320 hairpin from mike is $569.
The 275 hairpin is $499. Does 200+ at idle 275 at 2000 rpmThat's a little to high for me I'm staying around the 400-500 range with good idle amps
Let me ask u this Jim ..... What do u think about the price of eggs ?The 275 hairpin is $499. Does 200+ at idle 275 at 2000 rpm
ok that sounds a little better.The 275 hairpin is $499. Does 200+ at idle 275 at 2000 rpm
