High Level Input. Answer ASAP PLZZ
njknittle
PA
Quick question. The High Level Input connector has 4 wires. White(+) White/Gray(-) Black(+) Black/Grey(-). Its a powered subwoofer so everything is already to go. My question is, should I connect the High Level input to the original factory sub woofer wires? And if so, how do i connect the 4 wires from the High Level Input, to the 2 wires that are going into the factory subwoofer from the factory amp? Being a subwoofer, there are no right and left channels correct? Would just using the White , White/Gray off the High Level Input suffice?
Would really appreciate it if someone answered this as soon as possible. Im trying to get this thing in my car today=p
You could connect the 2 line level + wires to the 1 factory subwoofer + wire and the 2 line level - wires to the 1 factory subwoofer - wire.
Or you could just connect one side of the line level (left or right) to the subwoofer +/-.
Does your subwoofer amp have 2 RCA inputs?
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
433
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
410
You need to set the high pass filter for your 6.5" speakers. I wouldn't run anything lower than 80hz. 100hz would be alot safer. Adding a...
njknittle
njknittle
PA
keep_hope_alive
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
