Massive Audio N2 Mono Amp
  • 2
btolenti
In good condition. A few scratches here and there (paint coming off the mounting feet), but in good operating condition. Had it running JL W1 and it powered it very well. I was impressed with it given its size.
Specs
RMS Power Rating (14.4):
4 ohms: 200 watts x 1 chan.
2 ohms: 400 watts x 1 chan.
1 ohm: 800 watts x 1 chan.
Max power output: 1600 watts x 1 chan.
MOSFET power supply with high grade switching devices
LED power/protect indicators
Selectable bass boost (0, 6, 12 dB switchable at 50 Hz)
Designed to fit into restrictive or limited spaces while still delivering staggering amounts of power
Ultra efficient Nano Technology power supplies and endless possible installation scenarios
Monoblock operation
Extreme power in a small footprint
Ultimate mounting flexibility (stackable, line array, side mount)
Mill Spec double sided PCB with SMD parts
Built-In noise reduction circuitry
Heavy duty aluminum alloy heatsink are anodized in a Raven Black finish for extreme heat dissipation
3-Way protection circuitry (short circuit, overheating and Low Voltage)
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Adjustable low-pass filter (40-220 Hz, 24 dB/octave)
Subsonic Filter (10-50 Hz, 24 dB/octave)
Frequency response: 10-220 Hz
THD (Total Harmonic Distortion):
Signal-to-Noise Ratio: >80 dB
Max Voltage: 15V
Max RCA Voltage: 5V
CEA-2006 compliant amplifier
Weight: 7 lbs
Dimensions: 7-1/4"L x 5-1/2"W x 2-1/8"H
Asking $80 shipped or best reasonable offer.
Included in above.
  • Locked
hello mate, text me +1 (706) 300 5660 for quick response, if you need the Massive audio 15" dmx stage 2 for sale at a secondhand price, stay safe
  • Locked
Hello all, I am new to this forum but have had no luck on ebay/gumtree/fbmarketplace regarding trying to shift my aftermarket car audio setup. My...
It only works if you send rca signal through it to your amps.
984
btolenti
btolenti
Orange, CA
btolenti
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
