my jvc s79bt died
  • 2
Was it damaged mechanically, thermally, low voltage, high voltage, or other? If something scraped the board, you may be able to re-solder the connection. If it was damaged another way, there may be more issues.
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
Its a Hit or Miss on FB.Market Place for buying any electronics. Pull it and wire it up at the vehicles 12v battery to see if it powers on...
934
whojohnjones
whojohnjones
mississippi
adulbrich
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
