TheJesus 10+ year member
1. Product:
B2 Audio Duo V1
2. Specs:
The sound had to be different, the idea was to offer something unique. Excessive performance, advanced crossover section & the best possible input & output section. The Duo is all of the above, a 2 ch class A/B with listening pleasure to satisfy the audiophile & the ones seeking a dynamic amplfier, that will never lose its grasp of the music no matter the challenge.
A frequency response way beyond the audible, combined with a S/N ratio of 105 dB & an excessive capacitor section makes the Duo an excellent choice for the demanding listener. Whether it is used in an active or a passive system for tweeters, midwoofers & even subwoofers, the Duo will perfom to the fullest.
Frequency Response: 10 Hz ~ 40 KHz
Signal to Noise Ratio: 105 dB
Input Sensitivity: 6 ~ 0.2 V
Crossover: 18 dB / Oct
High Pass Filter: 20 Hz ~ 500 Hz / 200 Hz ~ 5 Khz (multiplier x 10)
Low Pass Filter: 50 Hz ~ 500 Hz / 500 Hz ~ 5 Khz (multiplier x 10)
Subsonic Filter: 10 Hz ~ 50 Hz
Bass Boost: 0 ~ 18 dB
Bass Boost Frequency: 35 Hz ~ 120 Hz
Damping Factor: 1000
Power Terminal gauge: 0 GA x 1
Fuse Rating: 300 A
Operational voltage: 11 V ~ 16 V
14.4V 14.4V Bridged Drop 14.4V Bridge*
Power @ 4 Ω: 2 x 600 w 1 x 1800 w 1 x 2300 w
Power @ 2 Ω: 2 x 900 w 1 x 2400 w 1 x 3000 w
Power @ 1 Ω: 2 x 1200 w*
3. Description/Condition:
Had it about a month, switching to a different type of amp. Worked great, clamped 1100W @ 6 ohms. Works perfectly at .7 per channel and I've been told they'll stay on wired way down. Looks fine, just some light scuffs.
4. Price: :
$600 + ship. Shipping from Sanford, FL 32773.
5. Pictures:
B2 Audio Duo V1
2. Specs:
Fuse Rating: 300 A
4. Price: :
5. Pictures:
