380a alternator chevy/gmc 5.3 vortec and 320a ford explorer will fit volkswgen too
jockhater2
380a chevy 4 pin
320a ford
380a less than 2k miles. 2 years old. only used for 3 months. idles at 14.7 cold and 14.4 hot
320a self turn on never used but mounted idles at 14.7 cold and 14.4 hot
will fit volkswagen at long it has the mk3 alternator bracket. or ABBA belt conversion on your mk2.
350 shipped for the 380a (paid $539 shipped)
300 shipped for the 320 (because of the cut of mount) paid $499 shipped for it.
What will the 320 fit and what brand? Msg me
Its supposed to fit a ford explorer v6 I believe somewhere around 2004. But I had to cut one of the mounts. That one I am 99% sure my friend is going to buy and make it work in his car.
Did you have a coolant leak of some kind or did oil leak??
That alternator is way to rusted from just normal heat wear.
You can even see it on the pulley. I guess im speaking of the gmc alt.
It sat in the trunk of the car for 1 year.
coolant wouldn't rust it. neither would oil. those would prevent rust.............
It sat in the trunk of the car for 1 year.coolant wouldn't rust it. neither would oil. those would prevent rust.............
Coolant does not protect from rust and neither does oil.
Oil sludges and creates rust & coolant contains water whether its 50/50,dexcool, etc..
Either way thank you for answering my question.
Coolant is a rust inhibitor. so are oils/greases.
If you are worried about the appearance of the alternator. I can come down another $50 and you can have Iraggi alternators clean up/paint the case.
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
358
I don't have one...but I check my voltage with a dmm once a week or so
592
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
What the ****? Are you trying to put ohm's law into very complicated verbiage?
928
jockhater2
jockhater2
Saukville, WI
jockhater2
ttt123
    Apr 16, 2024
ttt123
    Apr 16, 2024
