audioman14
1. GPS Antenna Cable
2. Video RCA (AV1): Aux-Out, Aux-In, Guide In
3. Audio RCA (AV2): Front, Rear, Sub
4. Power/Speaker Plug: 12V power, 12V acc, Ground, 4 sets of speaker outputs, Remote Turn-On, Amplifier Turn-on, Brake wire, Tel in
KCE-400BT to enable your Bluetooth® wireless technology compatible cell phone to sync up with your head unit that is ready for Bluetooth wireless technology. That way you're completely wireless, so you're free to focus on the road. with audio screaming
ALPINE HCE-C117D Direct Connect Mini Backup Camera Night Vision Car Truck Swivel
Direct connect rear view backup camera
High visibility in day and night environments
Wide viewing angle
Easy install with included bracket
Compatible with the INA-W910, INA-W900BT, INA-W900, iXA-W404, and iXA-W407
Dimensions: 3/4"D x 15/16"W x 15/16"H
Power Requirements: 6.0V DC (5.5 to 6.5V Allowable)
Ground Type: Negative ground type
Max. Power Consumption: 0.9W
Output Image: Mirror image, NTSC video signal
Image Output Impedance: 1Vp-p (75 ohm)
Image Sensor: 1/4 Type color CMOS
Aspect Ratio: 4:3
Effective Number of Pixels: 640(H) x 480(V)
Megapixels: 0.3
Focal Length: f=1.16mm
Brightness: f=2.8
Field Angle: 127°(H) and 101°(V)
good working and cosmetic condition Complete Cable
kce-400bt good working condition will work with iphone 6 and android 5s
ALPINE HCE-C117D good working condition when pulled out car
Complete Cables $75
kce-400bt $130.
ALPINE HCE-C117D $75.00
KCE-433iV $15
Apple Lightning to 30-pin Adapter $20.00
Lightning to VGA Adapter $25.00
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). "][/url]"]"]"][/url]"][/url]"]
Wide viewing angle
Aspect Ratio: 4:3
Megapixels: 0.3
Brightness: f=2.8
Complete Cables $75
kce-400bt $130.
KCE-433iV $15
