Alpine INA-W900, INAW900 Complete Cable Set RCAs, GPS. bluetooth backup cam
  • Participants list
audioman14
1. GPS Antenna Cable
2. Video RCA (AV1): Aux-Out, Aux-In, Guide In
3. Audio RCA (AV2): Front, Rear, Sub
4. Power/Speaker Plug: 12V power, 12V acc, Ground, 4 sets of speaker outputs, Remote Turn-On, Amplifier Turn-on, Brake wire, Tel in
KCE-400BT to enable your Bluetooth® wireless technology compatible cell phone to sync up with your head unit that is ready for Bluetooth wireless technology. That way you're completely wireless, so you're free to focus on the road. with audio screaming
ALPINE HCE-C117D Direct Connect Mini Backup Camera Night Vision Car Truck Swivel
Direct connect rear view backup camera
High visibility in day and night environments
Wide viewing angle
Easy install with included bracket
Compatible with the INA-W910, INA-W900BT, INA-W900, iXA-W404, and iXA-W407
Dimensions: 3/4"D x 15/16"W x 15/16"H
Power Requirements: 6.0V DC (5.5 to 6.5V Allowable)
Ground Type: Negative ground type
Max. Power Consumption: 0.9W
Output Image: Mirror image, NTSC video signal
Image Output Impedance: 1Vp-p (75 ohm)
Image Sensor: 1/4 Type color CMOS
Aspect Ratio: 4:3
Effective Number of Pixels: 640(H) x 480(V)
Megapixels: 0.3
Focal Length: f=1.16mm
Brightness: f=2.8
Field Angle: 127°(H) and 101°(V)
good working and cosmetic condition Complete Cable
kce-400bt good working condition will work with iphone 6 and android 5s
ALPINE HCE-C117D good working condition when pulled out car
Complete Cables $75
kce-400bt $130.
ALPINE HCE-C117D $75.00
KCE-433iV $15
Apple Lightning to 30-pin Adapter $20.00
Lightning to VGA Adapter $25.00
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). "][/url]"]"]"][/url]"][/url]"]
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Umm the sub outputs. It's brand spanking new with an install booklet etc.
409
Giving subs more power really wakes them up. The MRP-500 is pretty low power. You would really notice more authority in your bass.
478
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
642
Alpine has always made great products over the years.
545
audioman14
audioman14
Washington, D.C.
audioman14
Buck
    Mar 29, 2024
Buck
    Mar 29, 2024
