Audio Fading in and out
  • 4
  • Participants list
rollenhard
17
CA
64 Chevy Truck built engine no a/c or heater HEI Distributor
Need some help my pioneer MVH-X360BT Fades in and out only when the car is running.
when the car is off it works perfect
Its just a basic setup head unit and 2 front speakers
What i have tried
Direct hook up from +battery to radio
Direct hook up from -battery to radio still does the same thing Sound Fade In Fade Out
voltmeter Readings
yellow Constant hot
Engine off 12.33
Engine idle on 12.24
Red Ignition
Engine off 12.27
Engine idle on 12.18
Rev Engine Up Reading 13.9
What could be the problem?
Thanks
What source are you listening to when it fades? (Radio, CD, Aux?)
Do other sources fade?
When you say "fades in and out" does the sound cut in and out completely and suddenly, or the volume "floats around" softer~louder~softer ?
Does it do this constantly or just every once in a while?
It cut in and out completely. Radio and thumb drive No cd player
And its constantly when engine is running
Thanks
My jaguar I had a 355 in did the same thing. Stopped when I re did all of the engine and chassis grounds. Unfortunately I can't say what ground did it. Try grounding directly to the battery and see if it stops.
Assuming the radio is connected directly to speakers (not an amp) check each speaker for shorts. You can disconnect them one at a time and see if it stops cutting out. If either speaker wire shorts to ground the radio will mute everything.
Even When the engine is Off Jepalan ?
The radio works great no problems for hours when engine is off as soon as i start it it starts cutting in and out
Even When the engine is Off Jepalan ?The radio works great no problems for hours when engine is off as soon as i start it it starts cutting in and out
It all starting to sound like you have an engine ground issue.
Problem only starts when engine electrical starts up and not the accessory electrical.
Yeh, it was a long shot - I was thinking maybe car vibration was causing a stray strand to short out or something.
Have you checked the red switched +12 (ACCY) wire going to the radio?
If power and ground are good, then speakers is where I would look next.
For clarification - are you running any external amps or HU direct to speakers?
When sound cuts out is the radio 'sane' otherwise? (i.e. switches, controls, menus all still work?) Or does the radio go dark/dead?
Not running a amp just head unit and 2 front speakers thats it. I double checked all my grounds and speaker wires today and it still does it. When sound cuts in and out
all the switches, controls, menus display all still work
Could it be the HEI distributor causing the problem?
i know it may be a PITA, and it usually is... But id pull that HU out/ from the dash and check all your wiring connections and RCA connections...
88
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
547
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
611
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
rollenhard
rollenhard
CA
rollenhard
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
