Enclosure designs
  • 5
  • Participants list
skdooley
If anyone is looking for affordable enclosure designs I can be of service. I've been designing and building enclosures for over 5 years. Ported designs are $20, bandpass $25. I email a cut list along with multiple 3D pictures with measurements. I will need to know the subs you'll be using, the max dimensions of the space you have available, any clearance issues around the subs and/or port, as well as the amp (power) the subs will be on and the type of response and output you're going after. Depending on the subs, power, space and sort of output you want, I can help determine what type of enclosure may be right for you. You can respond here or shoot me an email at afanofdeftones@hotmail.com
hes legit i got a box built from his design in my truck right now ment for two 15 inch cvrs but used my hdc4 18 instead
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
503
i didn’t get to hear it yet. He’s supposed to install it this weekend.
30
skdooley
skdooley
Roanoke, Virginia, United States
CSCStang
SlugButter
    Mar 28, 2024
SlugButter
    Mar 28, 2024
