DC Power Inc 270A Alternator 02 Accord/ Acura CL *Extras!
  • 4
f1mclarenagr
4SKN
220
Milwaukee
270 Amp XP High Output Alternator for:
1998 -2002 Honda Accord 2.3L I4 F23A
1998 -2002 Acura CL 2.3L I4 F23A
Output Voltage 14.4
Idle Amperage 190
Hot Idle Amperage @ 200ºF 170
Max Amperage 270
Hot Max Amperage @ 200ºF 240
Full Specs
***Also including
- 0 gauge Knu Fleks run from alternator to battery.
- Correct serpentine belt for this alternator!
- Little spacer washers to take up the gap between the lower bolt and the mounting bracket
Cosmetically - 9/10 for an alternator... It sits inside the engine bay
Mechanically - 10/10
Received Novememberish 2012. Has around 15k-20k miles on it. Just took it out today! - 7/25/14
400 OBO - PayPal - No Trades!
Free
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
378
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
296
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
638
With 6500 rms.. you are still going to need some battery bank and/or supply for that demand
17
f1mclarenagr
4SKN
f1mclarenagr
Milwaukee
f1mclarenagr
1aespinoza
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
Latest topics
