Help! Shifted motor!
I'm very scared this motor is shifted! Please let me know or if it will get worse or if its fine! Any help will be appreciated!
[/img]
Also it's no bigger than 1mm
That's not what shifts, it genrally the pole and or top plate, I think you're fine unless it rubbing them I would say there's damage to the coil/former.
My brand new zv4 magnets are not perfectly stacked either, I think it's fine I would check the measurement around the gap and see if it's consistent.
73
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
156
350
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
241
Neily_OB_24
Bettendorf
Slo_Ride
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
