Jeffdachef 5,000+ posts
Gunz That Turn on Nunz
thought just crossed my mind, curious on what you guys think.
My uncle has a few gallons of these he got from his work and he's not using at all.
**3M
Itcan be used as a high strength adhesive+gasket
Can I apply that and some aluminium sheet metal MD Building Products 12 in. x 24 in. Plain Aluminum Sheet in Silver-56064 at The Home Depot and carefully bond it to troubling flat surfaces? Keep in mind this is to only eliminate flex, not really trying to dampen anything. My remaining 80 mill audiotechnix deadener didnt do much to stop the flex on a roof of a sienna. The thought of multiple layers of Second Skin just makes my wallet cringe if I ever go bigger with my setup.
In theory should be thicker and stronger then Damplifier Pro for flex treatment but I want your opinions on this matter. I'm sure many spl competitors have done this before but maybe in a different way, just forgot what they did. (psst: tell me what they did if you know)
Another question I have is. Do car surfaces get over 230 degrees Fahrenheit on a moderate climate?
**3M
