Threatcon-2 vs HDS3
MakkMar10
Bangin on a Budget
411
SoCal
So Iv been search'n an research'n a few weeks an I keep run'n into new factors to figure. Now im look'n at these T/S Parameters on wat i think are my final 2 choices. C2's Threatcon-2 12" rated @ 600wrms (750 version coming soon) or SQ's HDS312 rated 1200wrms.
Now the C2 seems to be the better choice not tht i understand the parameters but there lower an that seems to be better frm wat I'v read. Aslo iv read more power doesn't equal more output so there C2 also has the advantage seeing i only want to do a Big3 an under the hood batt only. So is the Threatcon-2 a better sub? Its only $20 more which is not an issue. Or does HDS's higher rms eaqual the parameters of the T-2 at half the rms, which then would make the HDS a better choice?
the amps aren't out yet
but
12.0 Volt Rating
SMD AD-1 Rating:
1 Ohm Dynamic Burst 3183 Watts
1 Ohm Non-Certified 2782 Watts
1 Ohm Certified 2485 Watts
Oscilloscope Rating:
12.0 Volt RMS power @ 1 ohm mono 2045 watts x 1CH
12.0 Volt RMS power @ 2 ohm mono 1413 watts x 1CH
12.0 Volt RMS power @ 4 ohm mono 789 watts x 1CH
Efficiency 4 ohm @ 12 Volts 88%
12.0 Volts 2 Amps strapped @ 2 Ohm Mono 4400 Watts
13.8 Volt Rating:
13.8 Volt RMS power @ 1 ohm mono 2707 watts x 1CH
13.8 Volt RMS power @ 2 ohm mono 1890 watts x 1CH
13.8 Volt RMS power @ 4 ohm mono 1061 watts x 1CH
Efficiency 4 ohm @ 12 Volts 90%
13.8 Volts 2 Amps strapped @ 2 Ohm Mono 5837 Watts
14.4 Volt Rating:
SMD AD-1 Rating:
1 Ohm Dynamic Burst 4157 Watts
1 Ohm Non-Certified 3537 Watts
1 Ohm Certified 3215 Watts
14.4 Volt RMS power @ 1 ohm mono 2982 watts x 1CH
14.4 Volt RMS power @ 2 ohm mono 2074 watts x 1CH
14.4 Volt RMS power @ 4 ohm mono 1169 watts x 1CH
Efficiency 4 ohm @ 12 Volts 89%
14.4 Volts 2 Amps strapped @ 2 Ohm Mono 6530 Watts
if you were thinking about getting that amp, either look into the Threatcon 4, or new C2 Team subwoofer otherwise, the HDS3 would be my choice of sub, and even then you're pushing it. Your best bet would be 1 HDC3 sir
You have to be talking about getting two subs. Running 3k you should do more than the big 3, since you only want to do that what kind of power do you want to run? For only big three most people will say no more than 2k.
but
12.0 Volt Rating
SMD AD-1 Rating:
13.8 Volt Rating:
14.4 Volt Rating:
SMD AD-1 Rating:
I know SMD is trustworthy, but those numbers look'd a lil to dam good. But $499 is the PreOrder price i seen....
I was think'n Id start with 2HDS's an 1 amp. As time an money permits I'l end up wit 2 HDC312's 2 of either Recon2.4 or Q2200 amp's. I'l only hav about 12-1500 to start. An i need a complete overhaul....im all Boss an Kicker rite now. Dam ebay was giv'n it away....still i was jus dumb then
Yea 2 12's....I want to do a Big3 an Batt under hood (EnerSys HX300). But yea looks like I'l go with the P900.4 an either this Recon2.4 or Q2200. Either way i want 2500wrms for 2 HDS's.....dam ima need to find space for another batt SMH.
I would buy the recon and for that much power the hds3's. the c2's are nice but I dont see them handling that power daily
If he picked up the C2 Audio Team 1k's (thinks still selling for $219 ea) 2 of them would take the power nicely. I'm running one on 1500 daily and it's great. Chris was doing torture testing on it with a DC 3.5k.
Yea Iv got the Recon over the Q22. Im sure the T-2 is a good sub but yea....No.
If i had experience with the HDS3 I'd give my opinion. I heard the SQ isn't as good in the HDS compared to the T2 from a friend of mine. But depending on your goals that should determine the sub. That recon 2.4 amp though will put in work for you! They should be getting to C2 this month
MakkMar10
Bangin on a Budget
MakkMar10
SoCal
MakkMar10
Random4thGuy
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
