So Iv been search'n an research'n a few weeks an I keep run'n into new factors to figure. Now im look'n at these T/S Parameters on wat i think are my final 2 choices. C2's Threatcon-2 12" rated @ 600wrms (750 version coming soon) or SQ's HDS312 rated 1200wrms.
Now the C2 seems to be the better choice not tht i understand the parameters but there lower an that seems to be better frm wat I'v read. Aslo iv read more power doesn't equal more output so there C2 also has the advantage seeing i only want to do a Big3 an under the hood batt only. So is the Threatcon-2 a better sub? Its only $20 more which is not an issue. Or does HDS's higher rms eaqual the parameters of the T-2 at half the rms, which then would make the HDS a better choice?
