1/2" MDF
if it's like under 300w, I guess so. If you turly want to maximise though, I strongly recommend that you try fiberglass.. they will be much thinner and stronger than 1/2" MDF.
Im about to build two underseat boxes for some Sony 10s to fit underneath the back seat of a 98-99 chevy silverado ext cab. Could I use 1/2" mdf to get as much air volume as possible or would it not be practical?Thanks
If you just running some sony's and want max airspace why not just use some good old cardboard and duck tape.
J/K, The 1/2" MDF would work fine especially since you got sony's
To tell you the truth though i have actually seen that done. All i could do was laugh my ass off until the guy was like what's wrong i thought it sounded really good. :hilarious
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
901
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
Yea. That's what I did. I mixed the glue with the dust from sanding and fill in the bigger holes. Then filled the rest with wood filler..works awesome
Yes Should be easy with a flush trim bit in a router and will allow OP to hide any screws/nails used along edges.
Bodawg111
Bodawg111
Longview, Tx
JnEsPappa
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
