What makes a subwoofer louder?
MakkMar10
Bangin on a Budget
411
SoCal
In my case im looking at 2 HDS312 then upgrade to HDC12, SA12, XFL etc. Anyway would i awlays need a sub spec box? An what makes, in a case the HDC @ 1500wrms louder than the HDS @ 1500wrms in the same box same amp basic sub switch?
Going from 2 HDS312s down to two SA 12s or XFLs wouldn't probably change anything.
Would sound **** near identical to each other.
The HDC3 on 1500 rms would do better than the HDS3 @ 1500rms because of more motor force, xmax, etc... And in the future you'd be able to up power without having to swap subs.
I'd say if anything, you should upgrade from HDS312s to HDC312s in the future. Swapping to XFLs/SAs would be a waste imo
Going from 2 HDS312s down to two SA 12s or XFLs wouldn't probably change anything.Would sound **** near identical to each other.
I didnt want to sound lik an SQfreak, but thats the ultimate plan HDS
each sub has different thiele small parameters and need their own enclosure to get the perfect sound and loudness comming from them. You cant just expect to keep the same box and put in different subs and say oh this sub is louder then this. Thats totally wrong because a strong sub in a bad premade box which will not sound loud or good meanwhile a weak puny sub can sound like a monster in a proper enclosure.
So should i wait til i can get HDC's? Or would my power supply also play a big factor? I can only find a YellowTop that'l fit my '10 Patriot, with that an Big3 how far would that get me? Im think'n that should be enough for an SQ2200d an P900.4. I want to start buying this weekend, but is it worth waiting another month for better subs?
2 HDC3s would laugh at the 2200. I ran my 2 off an AQ3500 and they handled it no problem.
You are going to need electrical upgrades.
Not worth getting the Hdc on that amp unless you run just one 15
I figured all that....So is it possible i could get a HDC spec box, throw HDS's in it an up grade as time goes on? Or should i just do 2 separate SubAmpBox set ups hahaha
I would clean the paint off that location and use two washers to sandwhich the ground wire to secure a solid connection and use a bolt rather than...
27
Don't get me wrong I've built a few boxes myself and I love doing it and it would've been preferred. But I now live in a one bed room apartment...
42
8K
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
Unfortunately barly someone does these things in my country, and the ones that do, makes it so expensive to test it or even fix it that testing it...
ringer ringer, chicken dinner... its your headunit. gotta upgrade mine as well, does the same thing, it cannot handle the additonal speakers, just...
MakkMar10
Bangin on a Budget
MakkMar10
SoCal
bbeljefe
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
