4 ZV4 12 Trunk Ground Pounder Flatline 7k Build
  • 2
bassheavy13
Premium Member
Premium Member
Alright, I blew 2 subs at SBN 2014 and decided to come back bigger. The goal is to get as loud and low as possible. This will be a cone area ground pounding trunk setup with 4 ZV4 12's. I am building this completely out of the trunk if you can believe it. I will accomplish this by making it with two separate boxes. There should be 3.5 cubes per pair of 12's after all displacements which is not optimal but I have heard them sound really good in under 1.5 cubes per sub. The amp that will make these thangs bang will be a Flatline 7k. Let's see what happens!
This will be box number one. There won't be any screws in this box, only clamped and glued.
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
662
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
971
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
bassheavy13
Premium Member
Premium Member
bassheavy13
Marietta, GA
bassheavy13
Chris Gerrish
    Apr 25, 2024
vlusardi
    Apr 24, 2024
