new truck, asking for box design help
  • 1
jokkr
i recently got a 2009 dodge ram crew cab. asking for help on a box design. it will go in the middle backseat floor. the sub is a jl 10w7ae. needs 1.5 cu. ft. at 35.3 hz. the pics i put together real quick have the dimensions i have to work with. i do not want the sub firing up. if i have to extend the box up over the middle of the back seat i am fine with that. the top part in blue is offset for the console lid when open. any help is greatly appreciated.
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
4
190
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
3K
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
8
ok i get it dodge ram and full strip inside for second skin . power is run down drivers side and speaker wire is run down passanger side thank you
jokkr
jokkr
Abilene, TX
jokkr
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
Latest topics
