Posted on the wrong forum, please delete, thanks.
  • 2
I need help on the amplifier settings since there are no good car audio shop around my area! And I believe you guys will have the knowledge to guide me through.
So I have installed an new amp and speakers, but I feel the speakers are still lacking of midrange.
My setup are as follow:
Speakers (tweeter, mid and subwoofer): Rainbow IL-C8.3 BMW F-Series Front semi – active“
3-way 8 inch (20 cm) Compo Set
25 mm Silk dome Tweeter
Max. 150 Watts
Minimum Amplifier Power: 75 Watts
Frequency Response: 35 Hz – 30 kHz
Amplifier: Rainbow Germanium Four
4 x 105 Watts @ 4 Ohm
4 x 140 Watts @ 2 Ohm
2 x 300 Watts @ 4 Ohm bridged
12 dB High Pass: 15 Hz – 500 Hz (5 kHz Front)
12 dB Low Pass: 50 Hz – 5 kHz
Dimensions (LxWxH): 420 x 235 x 55 mm
And here are my current amplifier settings:
4 Channel
Rear: Gain = Max, LPF= 80Hz, HPF=130Hz
Front: Gain = 80%, X-over is set as FULL, hence no LPF/HPF is set
Phase = 0%
How can I improve the midrange sound? Will turning down the treble and bass in my headunit help? Please let me know!
Thanks in advance!
OK so do you feel this is lacking mid-range, or mid-bass ? If you feel that you are lacking mid-range: YES you should be able to adjust your HU / EQ / X-Overs to overcome or at least improve upon this situation... If it's mid-bass you are after: Look into treating your doors on your vehicle if you have not done so already //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Thanks for your reply!
What i'm trying to match is to get the similar sound quality of my home speaker (Bowers & Wilkins Zeppelin Air)
The speaker also comes with tweeter, midrange and subwoofer..
So based on my amplifier settings, it looks good to go already? If so, I might try to experiment on my HU's EQ...
Thanks for your reply! What i'm trying to match is to get the similar sound quality of my home speaker (Bowers & Wilkins Zeppelin Air)
Are these mounted in a DOOR? If so - You won't likely EVER get the SAME sound as you do from your home audio speaker... But you should be able to "tweak" it to a better suited sound for YOU //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif It's all about what YOU like as far as sound is concerned, and tweaking amps, X-overs, and EQ settings properly can make or break you... It takes patience & trial & error... Just be careful as you don't want to blow those... And as I said before, if these ARE in fact mounted in your DOORS - Read up here: Doors | Sound Deadener Showdown
The midrange speaker is mounted in the door, tweeter was mounted at the triangle corner of the door windows next to the side mirrors, while the subwoofers are mounted under the driver and passenger seats.
I'm going to take a look at the link you show me. Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
When I was delivering pizza the companies had to raise employees wages and in response they hired twice as many employees and cut everyone's...
14
58
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
4K
Yeah, I plan to run them in my workshop. I haven't gone through them or anything but they startup and run just fine. I don't see any strange spike...
Antenna unplugged, noise reduced markedly but not gone. Plugged in again and ignition switched off, noise gone completely so antenna not the only...
10
hidehide
hidehide
Hong Kong
hidehide
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
