Southeast Region Gatordrag 2014 Custom Car & Truck Show
AR,AL,GA,FL,KY,LA,MS,NC,SC,TN,VA
  • 3
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
943
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
644
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
5
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
8
id put in a good new deck and front speakers, forget the rears (fade to the front). then when you get a new car, take the deck and front speakers...
973
gatordrag
gatordrag
Louisiana
tprj82
ttt123
    Apr 16, 2024
ttt123
    Apr 16, 2024
Latest topics
