5-6 channel amp
I have an mtx jackhammer jh805 it does right around 590 on the sub channel. I also have a directed 1100d5, with an extra str app able 600d. Strapped the amps do 800@4, 1200@2 and if your ballsy enough 1550 to 1600 @ 1. Just have to have the electrical to back it up. Not highly recommended by me due to the rarity of the amp. But it's been done
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
521
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
A 6 channel and a single sub amp would be my choice. Or a 2ch, 4ch and a sub amp. You don't need 2 channels for subs.
859
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
treylittlefield
treylittlefield
Sand Rock, AL
Chevy Blazin'
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
