Subwoofers not working ugh!
sundown-4-life
US
Car Setup
2 Sundown SA-8 D2 (each wired to 2 ohms)
Kenwood KAC-9105D 1800 watt amp w/ 4 gauge wiring kit
Alpine CDE 121 HU
Here is my issue.
Amp shows it is receiving power but the subs are not on. I know this could be many different issues, but I believe this is a loose RCA cable in the headunit. I checked the ground and there are not loose wires, the gain is properly set and the subs are not fried (aka blown voice coil). Is this a proper assumption to make? Also I am aware that the factory RMS is 500 watts but I am also under the impression that these subs were built for abuse. How many watts above the RMS value would it be safe to go?
Car Setup2 Sundown SA-8 D2 (each wired to 2 ohms)
Alpine CDE 121 HU
Here is my issue.
Are they wired correctly?
Yes i just went out to my car and checked everything. The subs are wired properly and the rca cable seems to be firmly in place. Do you think it may be internally within the HU?
Try the battery test first, place a double A battery on the speaker leads from the amp and listen if it makes subs any kind of sound, if it doesn't you have a break along the speaker wire or your subs are blown.
Lighten up man, it's all in good fun. Having more to go on than I want a sub that is less than 6" deep heps the forum narrow the focus. Why...
943
Adire Brahmas were incredible subs. One of the first subs that could really compete with the JL w7s. Super flat BL curve gave the subs a really...
915
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
Cool down, bro. and have a happy thanksgiving. I was merely inquiring in response to someone else's post that cautioned about clicking on the...
sundown-4-life
sundown-4-life
US
Beatin'
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
