How many volts can my sub take? JL 12 W6v2-4
HAWKONER
CA
I am wondering how many volts I should set my amp to put out.
The sub is a JL 12W6v2 wired at 2 Ohm. AMP is a JL JX1000/D
I'm measuring the voltage with a digital multimeter and a 50Hz tone.
The manual says the amps target AC voltage at 2 ohm is 44.7V.
I'd bet about anything that your sub is NOT a 2 ohm load at 50hz. If you're dead set on trying to use some sort of measurement equipment to set gains you should understand ohm's, and understand what an impedance curve is, and have a means to measure impedance at any given frequency.
Okay thanks for your reply I'm trying to figure it out. I found an ohm law calculator, if I want to give my sub 600w of power do i use a DMM to set the amp to put out 34.6 volts at 2 ohm??
Sorry if my questions dont make any sense its quite confusing for me.
Find your 75% volume of your head unit. Then unplug the speaker wire from the amp. Play your tone at 75% of full volume. I like to put the probes into the speaker wire clamps on the amp and tightennthe set screws onto the probes so you dont have to hold them. Set gain until you get your target of 44 volts. Thats about it. Hook your subs back up and listen to it.
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
HAWKONER
HAWKONER
CA
moneypit
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
