are these amps ok?
So I'm working with a pretty tight budget right now, and there isnt much space in my truck but I like to do things big and want as much sound as possible. I drive a 1996 extended cab chevy silverado (i have measured everything out and i have room for this)
the plan was to get 4 of these subs:
http://us.infinitysystems.com/product-detail-new-infinity-us/ref860w.html ($50 each on amazon)
and 2 of one of these amplifiers:
http://www.amazon.com/gp/product/B00...A1WRTEG7T8P2CK
or
http://www.amazon.com/gp/product/B00...A1FMHNVWMGI839
will these amps work with two subs running on each one? and does anyone have any suggestions for other subs or amps in this price category?
thanks.
With those subs mentioned, you would be best off getting a single 1 ohm stable amp and paralleling all the subs.
and I wouldn't run one amp on each sub, as no two amps are identical.... unless your strapping i'd just run one larger one... what type of sound you looking for?
i'd be running two subs off of each amp. and im looking for loud boomy bass. i listen to a lot of hip hop.
Op I have a 97 extra cab and a couple if boxes already built for 8s Get a 5 channel amp or a couple of mini amps Those subs won't take much power tho But I do have a box like u said and a amp to if interested the box I'd let go cheap just need to get it gone. Prolly like $30 plus actual shipping. Got to many need room
do this man killer deal and you will be getting a quality box vs anything pre fabed and the box is very important in a build and sound reproduction.
286
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
845
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
No doubt, was just thinking of that when i was mulling getting one of these. https://blackbrickaudio.com/products/100-watt-4-channel-amplifier
961
mrhelpesuhcs
mrhelpesuhcs
United States
globalminds_ent
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
