12 or bigger sub 1200 rms~
Sounds like you already have the amp. If you do what ohm does is put out 1200? I assume 1? If you just for some odd reason you want a 1200w sub at any ohm load sorry for the spam/bump.
David
David
He has almost 2000 poast to your 80 sum...I'm sure hes knowin
I have mused doing that, but I like keeping my jalopies looking OEM. Now if I knew how to fiberglass like NSTALN, I would have done it long ago.
22
Back in the day there was some that went directly into the dash and then came out when powered on. Some of those were bigger then the size you are...
608
Damn.. thank you man... I wasn't expecting you to do all the work for me but I'll definitely take it lol. Thank you so much and also thank you...
I sincerely appreciate the advice. I've made some changes to the design of my box and it's coming out to +8.99% larger than spec. I'll still be...
Different subs on Different amps in a shared airspace won't be good
72
SplAffair
I lol'd
SplAffair
Knocksville, TN
Mass Car Audio
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
