Is a Hifonics Brutus a "good enough" amp?
ckunke002
I understand that this is a relatively budget amp. On one hand reviews for them are all good, but some people trash on them here. It seems to be one of the top amps that will do 1k at 1 ohm for 150 bucks.
If I go into this not expecting top of the line efficiency and probably a bit underrated, will I be satisfied? Lol
Amazon.com: Customer Reviews: Hifonics BRX1100.1D Brutus Vehicle Mono Subwoofer Amplifier
Honestly, I doubt the 1100 actually does close to 1k, you're much better off going with something by Precision Power. If you're looking for 1k at 1 ohm, I'd get this: PPI BK1300.1D
Just set your gains properly and you'll be fine.
Hifonics is entry level, IMO. Several of their amps don't do rated, and they aren't what they used to be. Another company riding on their reputation from the 90's.
I have ran hifonics amps before and all ima ssay is back then for me it was more than enuff power with two bxi2008D's claming 4k rms.. look for a used bxi2008D seems to be one of the few amps u can still find for cheap from hifonics that dose n e wear close to rated..probly dose 1k rms maby 1500 with 16v....I talked to many people about n e thing they sell now.. DONT BUY IT!!!!
i'm interested to see what sort of replys you get //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Because you're wondering the question too, or because it's a bad question and the pros are going to rip me apart on it? hahah
You have a double edge sword here..."Affordable", "1k watts", "1ohm", and "reliable for years" is tough to find in one amp.
Take the "affordable" part out of the equation and you will be set "for years"
I would look into Arc Audio amps, maybe the ks1200.1 would work well for you...it wont cost a few hundred bucks though....but if wired correctly, it will last for years, provide rated power if not more, and make you happy.
I'd find a BRZ1200. Great budget amp, it'll do your 1K, and in my opinion, the BRZ line is the best Hifonics has ever offered.
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
ckunke002
ckunke002
Portland, OR
focused313
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
