Oldschool rockford fosgate punch 100z2
trenton
Amp is in mint condition literally no scratches
Has all screws an works flawlessly
Very beastly small amp
Great stealth amp an very underated
Specs:
25x2@4
50x2@2
100x1@4
Can handle 2 bridged almost certain an will do much more than rated
Be an awesome front stage amp
75 shipped
Hi ...looking for a small frontstage amp and I hope this will do....can you please give me the actual dimensions of this amp??
Also need to know if it tends to run HOT or not...and HOW it mounts, as I might want to mount it under the dash in a more enclosed space.
THANKS!!
sorry, another quick question(s)...I have seen that this amp has "end caps" that make it the dimensions the ones you quoted, yet the dimensions WITHOUT the endcaps are-- 10-5/16"W (6-3/4" w/o endcaps) x 2-11/16"H x 9-5/8"L .... soooooo, I am wondering if the amp can be used without end caps and if the end caps only cover the wires and also if your amp is pictured with or without the end caps???
VERY interested in it if it can be run without problems without the end caps, as it will give me a few more placement options...thanks again!!!
Yes I don't have the endcaps. They were there just to cover wires Runs the same with or without them
So it is actaully smaller then the dimensions you first sent me??
If so, I'll take it. PM reply with confirmation of size and your paypal address.
Adire Brahmas were incredible subs. One of the first subs that could really compete with the JL w7s. Super flat BL curve gave the subs a really...
918
369
The surprise wasn’t that they didn’t offer one…it’s how much engineering went into making it easily replaceable, and then not offering one. Maybe...
971
Thanks ya. Just pulled the trigger on the 1500BDCP because of the constant power that RF developed to help with the ohm rise.
887
trenton
trenton
charlotte NC
seafish
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
