Design Questions for 10" JL Audio 10 10W0v3 in 0.65 Cubic Ft Enclosure
  • 2
Turpy
Vehicle : 2008 Ford F-350 Lariat 4x4 Crew Cab
Location in the vehicle: 1st choice is behind the rear 60/40 bench seat or 2nd choice is a console box in the middle on the back seat floor.
Space available (Length x Width x Height): Depends on location
Subwoofer make and model: JL Audio 10W0v3
Subwoofer Size: 10" (4.9" mounting depth)
Number of Subwoofers: 1
Type of Port (Kerfed, Slot, Aero, etc.): None
What type of music do you like?: Country & Rock
Is your goal SPL or Everyday Music?: Everyday (Thump)
Tuning Freq (Hz): See Below
Volume : 0.65
Questions: I want to build the cheapest enclosure rather than buying one for more than 3x the price!
Here is the recommended box specs from JL Audio:
Wall Thickness: 0.75 in / 19 mm
Front Baffle Thickness: 0.75 in / 19 mm
Volume (net int.): 0.65 cu ft / 18.41 L
External Width (W): 18 in / 457 mm
External Height (H): 11 in / 279 mm
External Depth (D): 9 in / 229 mm
F3: 42.4 Hz
Fc: 53.23 Hz
Qtc: 1.002
Well, ya see that's just the thing. The dimensions are so complicated that I'm simply hoping that someone already has plans for my truck. I know how to calculate air space and build a box, I just need help deciding where and details. I have found a box online, but they obviously don't give away their dimensiona. Maybe I'm asking the wrong people.
If you're serious about an 18 in the trunk front firing/trunkwalled go ahead. At least you got electrical covered /w/ a 600rms sub I'd wager. If...
16
Not sure if this is reliable but trying to figure it all out on my own at this point. Does this look good?
729
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
523
Turpy
Turpy
Elwood, IN
Turpy
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
