Central Region Heat Wave, Corpus Christi, TX - 5-6Oct2013
IA,IL,IN,KS,MI,MO,MN,NE,OH,OK,TX,WI
  • 1
  • Participants list
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
Are there any label making machines available that allow you to print directly on your currently owned heat shrink and not from a manufacturer...
Any air movement is helpful in keeping any amplifier running cooler as long as there is a way to release the heat build up. I install all my amps...
Upside down should be fine. Airflow is all that matters. My buddy did this install. I think 14 amps. Look at that sloppy wiring. 😂 Vegas don't play.
4
964
gckless
gckless
San Antonio
gckless
Doxquzme
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
Latest topics
