Callingindogs 10+ year member
I was wondering what the rms rating of the tweeters are, getting a new MB Quart RA1000.4 and running active.
Thank you for the input!where you set crossovers will be largely determined by your specific installation and angles relative to on-axis for each ear. you need to factor in beaming and polar response into your crossover point planning. then let your ears be the judge from there.
if you have more detailed questions on that, feel free to ask. i'll need pics of mounting (with and without door panel on), distances and angles relative to center axis on each, and distances to each.Thank you for the input!
At the moment i'm really deciding on whether to go active or not, as far as how much better it sounds, is it worth the trouble? I'd either be going active with a MB Quart RA1000.4 as the amp and a Pioneer 80prs as the headunit. If I didn't go active i'd add 6x9's to the back deck of my car.if you have more detailed questions on that, feel free to ask. i'll need pics of mounting (with and without door panel on), distances and angles relative to center axis on each, and distances to each.
Would you recommend it highly over not going active?if you have more detailed questions on that, feel free to ask. i'll need pics of mounting (with and without door panel on), distances and angles relative to center axis on each, and distances to each.
