Precision Power vs Hifonics
Braindead
York, SC
I'm looking in terms of how clean the power is. It's between a precision power p1000.1, bk1300.1 or the hifonics 1100.1. I'll go ahead and say that the hifonics looks sexier to me so it wins points there.
Also, im running them at a 1 ohm load
let us know what is your budget unless those are the only 2 you want, vs dont ussually work since you close your options to other amps
220, I'm open to any good amps. Almost closed a deal for a JL but i didnt have enough money in time
They will both do good amounts of power clean. That's like saying what's better: a blue car or a black car. I'd take the PPI 1000.1 out of the equation though - it'll do slightly less power. It's made to have a small footprint. I run both PPI and Hifonics in my car and I'm impressed by both. The Hifonics seems to be a bit sturdier though, the PPI doesn't have much going for it as far as heat dispersion goes.
I'm between a black ice 1300 and a brutus 1100.1. Looking at it, can i secure the black ice to my box with screws?
I'd personally go with the BRX1100 just because they're built like tanks.. Well, a chinese tank that is. Lol. They're both good choices, but like I said, the PPI just seems to be made "cheaper"
I'm saving $20 going with the ppi. What do you mean by cheap, are they made out of plastic and just feel kinda b*tchy?
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
391
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
302
648
Braindead
Braindead
York, SC
fasfocus00
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
