Precision Power vs Hifonics
Braindead
York, SC
I'm looking in terms of how clean the power is. It's between a precision power p1000.1, bk1300.1 or the hifonics 1100.1. I'll go ahead and say that the hifonics looks sexier to me so it wins points there.
Also, im running them at a 1 ohm load
let us know what is your budget unless those are the only 2 you want, vs dont ussually work since you close your options to other amps
220, I'm open to any good amps. Almost closed a deal for a JL but i didnt have enough money in time
They will both do good amounts of power clean. That's like saying what's better: a blue car or a black car. I'd take the PPI 1000.1 out of the equation though - it'll do slightly less power. It's made to have a small footprint. I run both PPI and Hifonics in my car and I'm impressed by both. The Hifonics seems to be a bit sturdier though, the PPI doesn't have much going for it as far as heat dispersion goes.
I'm between a black ice 1300 and a brutus 1100.1. Looking at it, can i secure the black ice to my box with screws?
I'd personally go with the BRX1100 just because they're built like tanks.. Well, a chinese tank that is. Lol. They're both good choices, but like I said, the PPI just seems to be made "cheaper"
I'm saving $20 going with the ppi. What do you mean by cheap, are they made out of plastic and just feel kinda b*tchy?
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
379
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
297
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
639
Braindead
Braindead
York, SC
fasfocus00
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
