2 13w7s needin advice
you other option is to wire to .375ohm I believe and your amp will not handle that
why would you say it then? lol
anyways yeah your amp cant do that run with the link he gave you at first...but ultimately get a bigger amp or another one...
or just run one of the subs
With the subs wired to 1.5 ohms like is described in the link, your subs will sound just fine. Don't buy into the whole "underpowering" nonsense. Your amp will push somewhere in the neighborhood of 1500 watts to those two subs which is more than enough to get them to get very loud. This is assuming that it is the bdcp amp. If it were an older one, it would do slightly less(1200-1400) at that 1.5 ohm load, and you probably would not be able to hear the difference.
Just traded my 1500 birthsheet said it did 1763 at m @14.4v and 1900ish at 1 ohm. So i would say yes it is right there at the sweet spot at the 1.5 ohm load.
+1
+1
I looked up the specs on the new rockford power1500 and...
Rated Power
(RMS Continuous Power):
1000 Watts x 1 @ 4-Ohm
1500 Watts x 1 @ 2-Ohm
1500 Watts x 1 @ 1-Ohm
so wired to 1.5, you should get the 1500 max rating and I agree with the other guy, it will be loud.
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
245
I always leave approx 6" or so for that very reason, in case I decide to swapp an amp if needed,or wanting too.RCAs ect. I deff do the extra 6-8"...
9
394
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
4
343
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
255
mulletman.zane
mulletman.zane
Centralia, IL
maddog
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
Latest topics
