MXcaraudio New amps to test and play with
  • 2
naughtyca
Tampa FL
Got 2 amps to play with 600.1 @ 2 ohms and 2000.1 @ 1 ohm
MX600.1
SPECIFICATIONS
RMS @ 4ohm - 14.4v 400w*1
RMS @ 2ohm - 14.4v 600w*1
Remote Bass Boost Yes
Subsonic Filter Range Variable (10Hz - 50Hz)
Bass Boost +18dB (Variable 40Hz - 100Hz)
Crossover LP (50Hz - 250Hz) 24dB
THD 0.05%
Fusing 30A*2
MX2K.1
SPECIFICATIONS
RMS @ 4 ohms - 14.4v 850w*1
RMS @ 2 ohms - 14.4v 1350w*1
RMS @ 1 ohms - 14.4v 2000w*1
Bass Boost +15dB@40-100hz
Crossover 50hz-250hz variable 24dB
Subsonic Filter Variable (10hz to 50hz)
DC fan
THD 0.05%
External Fusing 200A recommended
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
281
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
841
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
No doubt, was just thinking of that when i was mulling getting one of these. https://blackbrickaudio.com/products/100-watt-4-channel-amplifier
959
naughtyca
naughtyca
Tampa FL
naughtyca
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
