12" Alpine Type R's cut out
Noob@Bass
I recently purchased two 12" Alpine Type R's (SWR-1222D) subs and an 1100 watt RMS amp (Alpine MRX-M110). I have them wired for a 2 ohm load i believe. I can only turn my amp gain to about 1/8 turn up and my subs will cut out at 18 volume. I know these subs can handle more than that and I don't know what to do. Maybe my wiring is for a 4 ohm load? Help
take a picture of how you have them wired. If you don't know exactly how you have them wired, you need to.
That is how you should have those subs wired.
I checked and that's exactly how they're wired. So I'm assuming I have them wired correctly. I was trying to set my gains and before I even hear distortion my subs cut out. That's on 3/4 volume and about 2/5 turn up on gain.
Sounds like its possible there's a bad connection either your power or ground wire to the amp causing the amp to go protect due to being starved for power under heavy load. Check all connections be sure there's no paint on any metal surfaces and that all connections are tight.
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Umm the sub outputs. It's brand spanking new with an install booklet etc.
402
Giving subs more power really wakes them up. The MRP-500 is pretty low power. You would really notice more authority in your bass.
471
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
639
Alpine has always made great products over the years.
543
Noob@Bass
Noob@Bass
North Dakota
The Audio Guy
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
