Need Help Choosing an Amp For Kicker Cvr 12's!!
  • 4
Jberny90
Well like the title says i need help choosing the best type of amp for my subs, theyre dvc 4 ohms,450 rms handling. I thought 2 channel was the best way to go but i read somehwhere that a mono block wired at 1 ohm would really make these subs pound! Im just trying to make these subwoofers bang as loud as i can get them to with the best combination, i dont want to spend alot on an amp since these subs arent brand new either, Thanks
I heard that too! Yeah, kickers always sound best wired to 1 ohm on a mono-block.
Hey, just yanking your chain. Check it out- It doesn't matter how many ohms the subs are wired to, it just matters how much RMS they are receiving. You could have a class A/B multi-channel amp running 450w, each sub wired to 2ohms OR you could have 900w going to the pair at 1ohm. It is up to you, my man. As far as a recommendation? Buy whatever fits your budget, keeping your newly acquired knowledge in mind. As with anything in life, you are going to get what you pay for. Not to say a cheap amp wouldn't do completely fine... The difference is the quality of construction, materials used, features, and longevity. Good luck //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I am currently running two 12" dual 4 ohm cvr's, same as yours, wired to two ohms each, at 500 rms each on a class a/b 2 channel amp Audiobahn a8002j that I got from vminnovations.com or sonicelectronics.com, not sure which just which is cheaper, but they sound great. True they are prolly only getting 350-400 watts and can take more but they are rattling my *** pretty good
Here is my thought, theory. Those speakers are 80w rms. Half of that is 40w rms. Add the 40 to the 80 and you get 120w. Get an amp that is 120w...
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
7K
I have 2 Sundown SA10v2 (1000w version) and just replaced my RF R1200 with a T-1500.1bd and OMG! I was considering Ampere Audio, JP23, Sundown...
well, thats kind of an open ended question....., you can do 2500rms@1ohm, or you can do a pair of 1k-1200rms@2ohms. just have to know the amp...
Jberny90
Jberny90
East Phoenix,AZ
chefzane
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
