DallasOldSchool
Host to sales and advice
These are über rare. I'd like $300 for the pair. Pm or post with questions.
This is txt from the spec sheet...
HZ 8 SPECIFICATION SHEET
You have purchased the finest car audio loudspeaker available.
HZ Bass Drivers set new standards for performance and reliability.
They are superbly crafted and precision calibrated.
If you install each loudspeaker properly, you will be astonished with the quality of sound and you will
have an audio system that you can be proud of and enjoy for many years.
HZ 8 SVC
Nominal Impedance……………………………………………4ohms
Re (DC resistance)…………………………………………...3.3ohms
Levc (coil inductance)………………………………………..0.29mH
SPLo (reference efficiency) @ 2.83v…………………….87.2dB
Fo (free air resonance)………………………………………..44.6Hz
Qms (mechanical Q)……………………………………………..…3.13
Qes (electrical Q)…………………………………………………….0.89
Qts (total Q)…………………………………………………………….0.69
BL (force factor)……………………………………………………5.5TM
Sc (cone area)…………………………………………….0.0206 sq M
Vas (volume acoustic suspension)…………………26.3 Liters
Vas (volume acoustic suspension)…………………..0.93 cu Ft
Xmax (excursion)………………………………………………..7.0 mm
Pmax (thermal power handling)…………………….300 watts
Mounting Diameter…………………………………………….7.75 in
Mounting Depth……………………………………………………4.0 in
Basket Displacement……………………………………...62.5 cu in
Voice Coil Diameter…………………………………………......1.5 in@%1;
HZ 8 SVC
