rumble sound from subs when i turn on/off cd player and when i turn bass knob up
  • 2
Haystak
ill start with saying i have a sundown audio saz-2500, two DD 2512s ported bbox, optima yellow top, 0 gauge streetwire wiring kit.
ground is connected to a seatbelt bolt in back seat.
from subs to amp i using 8gauge..theres terminals on my amp so i basically have both wired seperatly at 2 ohm each...(pos to pos to pos neg to neg to neg) so if im right that equals 1ohm load
problem: when i turn the bass knob up i head a rumbling sound (only first few notches on knob though) and when i turn the cd player on (when amp turns on) you hear kind of a pop sound
i understand...but it has two sets of terminals that are internally connected.....so if i do Option 1 (parallel) = 2 ohm load Voice coils wired in parallel
so if i do that to both and have each connected to their own terminal that would make 1ohm...right? or do i have to wire the subs together? and i dont have a DMM :/
I have my big 3 done in 1/0 so I got those grounds done up front. Both amps have their grounds to the reserve batteries on buss bars. Sub amp has...
Hey all. Just took my car audio batteries out to build a box for them. When I hooked everything back up and turn it on. My subs have a constant...
Very Nice!! I wished Id seen this two months ago. I ended up picking up a BNIB Sony XEC-1000. GLWS!! Ill chew on it a bit,and may pick it up??
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
524
Haystak
Haystak
Gatlinburg Tennessee
Haystak
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
