pioneer park brake wire question
musclesoh92467
could anyone tell me if i have the correct diagram for wiring a parking brake bypass on a pioneer avh-1500 and will this enable to use dvd player anytime also i have my amp blue wire connected to my radio ignition wire so do i need to reconnect that or leave that way it is if i follow this diagram ? thanks
Dvd only turns on when the parking brake is on? My guess would be that when the brake is engaged it either completes a ground or sends a remote signal, just replicate that into the did player harness. That way you brake dash light wouldn't be on. I feel as though I'm not making any sense.
Yea the switch sounds like good idea..so connecting park brake wire to a ground should accomplish samthing? I just wondered if thats so why anyone buys a bypass or relay if simply attachin to ground??
I just did this to my avh-p2400bt, bought a $10 relay off ebay that tricks it into working at all times, grounding the parking break wire wont work on Pioneer
grounding pioneer works with toggle switch. I have done it on avh-x8500bhs,avh-x5500,avh4300dvd, avh3200 an avh3300bt
been a few years since I did last 2 pioneers I listed hope I got model numbers right
My most recent Pioneer did need a ground, but not a constant ground. You need to be able to interrupt it to make the screen active. Just wire it through a simple toggle switch to ground. You will need to just throw the switch back and forth (open to closed) after the player powers up. The "black box" they sell on eBay and such is just that on a time delay so it flicks after the unit powers up.
If you're not sure what I mean, just hook it up and hold the P-brake wire in your hand and see what happens when you ground it at various times.
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
185
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
623
musclesoh92467
musclesoh92467
dunmore,pa
musclesoh92467
1aespinoza
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
Latest topics
