Little help
  • 2
gumby688
Ok getting ready to build my enclosure for 6 12 inch punch hx2's my net internal volume is 14.2cu ft after bracing, ports, (if I use the 5 4inch ports at 11 inches) and driver displacement. I have a couple questions. Want to tune somewhere between 32hz and 35hz. Building for SPL but dont want a 55 hz burp box want something I can live with for everyday. Going with subs up and port firing to rear of my 2000 2 door explorer sport.Will be running them on a popcorn sounds 4k am at .67ohm figure I will be doing good to get 2600-2800 from the amp. Using 3/4 birch plywood box dimensions outside 48 inches wide 21.5 inches tall and 30 inches deep.
1. Should I go with 5 4inch areoports or a slot port?
2 If slot port I need the size and best location in back of enclosure. top, bottom, center verti, center horz, left side or right side.
Here are the specs I have for the subs with RF recomendations for box and ports.
Punch HX2 DVC RFD2112
Nominal Impedance (ohms) 2 (2)
Voice Coil Diameter-inch 3.0
FS (Hz) 25
QTS 0.407
VAS-cu.ft. 2.86
Xmax-inch .55
SPL (dB @ 1w/1m) 86.7
Power Handling (RMS) 500
Power Handling (Max) 1000
Mounting Dia.-inch 10-13/16
Mounting Depth-inch 5-13/16
Speaker Dis.-cu. ft. 0.069
Sealed Box Vol.-cu. ft. 1.25
Vented Box Vol.-cu. ft. 2.0
Port Diameter & Length 4 inch dia x 10.75 inches
Would you mind if I designed this for you? That's just a ****** setup.
Help is always a good thing the dimensions on the box are the biggest I can fit in and still have a back seat and for my class I have to be under 24inches from the floor of rear cargo for total height
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
12
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
134
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
172
11
376
gumby688
gumby688
Fryeburg,ME
gumby688
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
