What sub?
  • 4
chsvick5
Guys looking to get some help on my future upgrade. I currently have 4 12 lanzar opti. I have a 2002 impala. Alternator 240 amps kinetik battery 1400. For the amp I just recently ordered a DC 5k and waiting on the arrival still. So I'm debating I want 2 18. Will be in trunk and box will be the whole trunk. So it's either 2 18 DC level xl or 2 dd3518. If any other brand let me know as well with price. I want my budget to be around 1100 for both. I will mostly likely by one then the other. I want to run them at 1 ohm so wat vc should I get?
Swap out the kinetic to Optima yellow tops, Xs power, deka group 31 batteries. If you really want the 18's do a flat wall and a clean amp rack in the trunk so you can acress the spare tire if needs be. I'd do 2 obsidian 18" v2's, they're reasonably priced and can take a lot of power.
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
479
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
335
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
481
chsvick5
chsvick5
Laredo, TX
mylows10
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
