Well here is my setup:I am running a capacitor and that is going to my amp. I am running a Boss PG2.1500 amp. I have two Boss P156DVC.
Amp Specs:
Amplifier Class AB
Number of Channels 2
Total Peak Power Output 3000 watts
Total RMS Power Output 1500 watts
Maximum Input Gauge Size 4 AWG
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.01%
Speaker Level Inputs Yes
Preamp Outputs No
Built-in Crossover Low-pass (LP)
High-pass (HP)
Full (AP)
High-Pass Crossover Frequency 50 - 150 Hz
Low-Pass Crossover Frequency 45 - 90 Hz
Signal-to-Noise Ratio 103 dB
Channel Separation 90 dB
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled No
Fuse Rating 35A x 2
CEA-2006 Compliant No
Sub Secs:
Subwoofer Series Phantom
Subwoofer Size 15"
Peak Power Handling 2500 watts
RMS Power Handling 1500 watts
Voice Coil(s) Dual
Impedance (Per Voice Coil) 4 ohms
Frequency Response 25 - 1,000 Hz
Sensitivity 96 dB
Subwoofer Design Round / Circle
Main Cone Color Black
Woofer Composition Injection Molded Polypropylene (IMPP)
Woofer Surround Butyl Rubber
Subwoofer Grille No
Re-Cone Kit Available No
