S10 blowthrough help
  • 4
  • Participants list
S10SPLove
I'm going a start a blowthrough project on my singlecab s10. Im going to be using 2 hdc3 subs and can't decide between 12s or 15s. I'm going for spl obv given the subs I'm using. Someone help me out here on deciding sub size. Also I'm torn between a 4th order (confused as hll on how to build one that will sound good) or a regular slot ported box... I'm leaning towards ported. Should I make 2 chambers w 2 ports. Or a single chamber w one port? Helllp.lol
I'd do 15's if they'll fit. Seems silly to cut up a vehicle for 2 12's.
HDC's are not 4th order friendly. Do a reg ported box, single chamber and center port. Also depending upon where the box ends up and if you have to use panels to seal it off into the cabin that might lower tuning...
What do u mean panels? I planned on sinking the face of the box in about 2 inches so there's a lip on the front of the box. I've never owned 15s. Are they alot different then 12s sound and knock? Thanks for the info on the box tho.
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
120
I have a bunch of amp but the sundown and the skar are two highest wattage ones. what amp would be needed to be enough for that skar 15" i thought...
18
423
That is correct. I like these as they are twisted pair and the RCA ends are thick and grip quite nicely...
9
321
S10SPLove
S10SPLove
Portland CT
Buck
Doxquzme
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
Latest topics
